[mapguide-users] Fusion Save Map Issues
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Aug 15 13:32:11 EDT 2008
Exactly what did you do to fix this? When I edit the XML for that widget
(using the Edit XML button in Studio) I end up with a messed up Fusion
layout - all of my toolbars vanish except for 2 SaveMap widgets that
show up (neither work, of course).
Andrew
Rock Beans wrote:
> I am getting a DWF now after fitting it with the proper XML tags. I
> wonder why our code is different. I had to use UiWidgetType where you
> used Widget. Right now I click on the button and a flyout with the
> name of the print layout comes up with another flyout for scales. I
> think the problem is MapGuide Studio 2009 does not handle this
> properly. Any information on this?
> <?xml version="1.0" encoding="utf-8"?>
> <UiWidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
> <Name>SaveDWF</Name>
> <Type>SaveMap</Type>
> <Extension>
> <Format>DWF</Format>
> <PrintLayout>
> <ResourceId>Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout</ResourceId>
> <Scale>10000</Scale>
> <PageHeight>8.5</PageHeight>
> <PageWidth>11</PageWidth>
> <Margins>
> <Top>1.5</Top>
> <Left>0.5</Left>
> <Bottom>0.5</Bottom>
> <Right>1.5</Right>
> </Margins>
> </PrintLayout>
> </Extension>
> <ImageUrl>images/icons/file-save.png</ImageUrl>
> <ImageClass />
> <Label>Save as DWF</Label>
> <Tooltip>Click to save the current map as a DWF document</Tooltip>
> <StatusText />
> </UiWidgetType>
> On Thu, Aug 14, 2008 at 12:07 PM, Jason Birch <Jason.Birch at nanaimo.ca
> <mailto:Jason.Birch at nanaimo.ca>> wrote:
>     What does your AppDef look like for that widget?  This is working
>     in my map (credit to DM Solutions):
>     <Widget xsi:type="WidgetType">
>     <Extension>
>     <PrintLayout>
>     <Name>First</Name>
>     <ResourceId>Library://Nanaimo/Apps/NanaimoMap/PrintLayouts/NanaimoMapDefault.PrintLayout</ResourceId>
>     <Margins>
>     <Top>1.5</Top>
>     <Left>0.5</Left>
>     <Right>1.5</Right>
>     </Margins>
>     </PrintLayout>
>     </Extension>
>     <StatusText/>
>     </Widget>
>     If this doesn't work, all I can suggest is adding a bunch of echo
>     statements to the code to see what state the variables have at
>     different points in execution.
>     Jason
>     *From:* mapguide-users-bounces at lists.osgeo.org
>     <mailto:mapguide-users-bounces at lists.osgeo.org>
>     [mailto:mapguide-users-bounces at lists.osgeo.org
>     <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf Of
>     *Andrew DeMerchant
>     *Sent:* Thursday, August 14, 2008 09:27
>     *To:* MapGuide Users Mail List
>     *Subject:* Re: [mapguide-users] Fusion Save Map Issues
>     No idea on the fix, but I can say I have the exact same problem
>     here....I've yet to really look into what might be the problem -
>     in hopes that I might be able to sort it out myself.
>     Andrew
>     Rock Beans wrote:
>     I changed the mime type to text and got this output:
>     <br />
>     <b>Fatal error</b>:  Call to a member function Read() on a
>     non-object in <b>C:\Program
>     Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\MapGuide\php\SaveMap.php</b>
>     on line <b>104</b><br />
>     Any ideas?
>     The Rock
>     ---------- Forwarded message ----------
>     From: *Rock Beans* <rockbeans at gmail.com <mailto:rockbeans at gmail.com>>
>     Date: Thu, Aug 14, 2008 at 10:30 AM
>     Subject: Fusion Save Map Issues
>     To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org
>     <mailto:mapguide-users at lists.osgeo.org>>
>     I am on the latest SVN release of Fusion and when I click save map
>     I get a Save/Open dialog now. The problem is the image is only 207
>     bytes and not readable by any image program. I tried DWF and the
>     DWF viewer said it could not open the DWF files as well. What am I
>     missing please? IS the output buffer or the MIME type not working
>     correctly?
>     Fusion r1461
>     The Rock
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     *Andrew DeMerchant*
>     *Computer Technologist*
>     ph.1-877-2GEMTEC x.163
>     fax 506-453-9470
>     /GEMTEC Limited <http://www.gemtec.ca>
>     /191 Doak Road
>     Fredericton, NB, Canada
>     E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
