[mapguide-users] MGOS 2.0.1 Crash Issues
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Aug 17 15:22:57 EDT 2008
Have you tried to add the provider(s) as having a connectionpoolsize of one?
(in serverconfig.ini)
It is bound to give really bad performance, but it may give stability.
If it gets stable with only one connection, the issue is likely a
threadding problem in MG or the provider.
Regards, Kenneth Skovhede, GEOGRAF A/S
nclayton skrev:
> Something else I forgot to mention, thanks for bringing that up Andy!
> I'm running IIS / PHP and using MySQL for the backend (using odbc
> connections instead of mysql connections)
> Andy Morsell wrote:
>> I have similar crashing problems with 2.0.1 and also suspect raster
>> issues,
>> although there are no clues in the error or event logs about this.  The
>> reason I suspect raster issues is that when things start to go wonky, maps
>> with no raster work for a little while maps with raster fail to render.
>> Eventually, mgserver faults and locks up.
>> The one common denominator for those with instability issues seems to be
>> running MGOS with IIS / .NET.  Is that the case for all with these
>> problems?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Thursday, August 14, 2008 8:37 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MGOS 2.0.1 Crash Issues
>> how do they perform if you remove the rasters ?
>> On Fri, Aug 15, 2008 at 1:23 AM, nclayton <nclayton at gmail.com> wrote:
>>> The old server is no longer in use so I can't give specifics on its
>>> specs.
>>> The new box is:
>>> Windows 2003 Server Standard Edition SP2
>>> 2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
>>> IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
>>> Application Pool)
>>> 4GB RAM
>>> Attached is my serverconfig.ini file. I didn't make many changes to it,
>>> other than changing the repository paths. I honestly am not 100% sure of
>>> what effects most of the settings have on the system.
>>> Here's a list of the currently available urls in case someone might can
>> see
>>> something I've done in the maps that could cause some of my problems:
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
>>> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
>>> They all use the same layer styles...I just copy the layers to a new
>> county
>>> folder, change where the file points to and add it to a new county map.
>> Each
>>> county has a set of ECW raster files.
>>> zspitzer wrote:
>>>> can you describe the specs of the two machines ?
>>>> had you tweaked the serverconfig.ini for the size of the machine?
>>>> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>>>>> yeah, I had that in place. It's odd that some of these errors only
>>>>> started
>>>>> happening on this new box which has a lot more horsepower than the
>>>>> previous
>>>>> one.
>>>>> i'm going to keep mgos installed and try to do some testing to try to
>>>>> figure
>>>>> out what exactly is causing things to die on me.
>>>>> Rock Beans wrote:
>>>>>> That is to bad. It might have been something easy to fix. Was you
>>>>>> installation patched to fix the Firefox 3 crash bug?
>>>>>> The Rock
>>>>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>>>>> maps
>>>>>>> back
>>>>>>> to mapguide 6.3
>>>>>>> hopefully things will smooth out more in future releases.
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com (My Blog)
>>>> +61 405 847 168
>>> http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
>> Zac Spitzer -
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080817/c2b98f5e/attachment.html
