[mapguide-users] How to export a WebLayouts toolbox and menu configuration
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Aug 17 15:45:57 EDT 2008
No, I don't think it is documented anywhere (at least not as clear as
below).
Regards, Kenneth Skovhede, GEOGRAF A/S
stoff skrev:
> Dear Kenneth,
> thanks a lot for your good explanation. It helped a lot... !
> It is not documented anywhere, isn't it?
> Best regards,
> stoff
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> If you right click the WebLayout after it has been created, you can
>> choose something like "Save to Xml...".
>> This is the xml file.
>>  From Studio, you cannot restore the file, but you have 2 options:
>> 1. Go to:
>> http://localhost/mapguide/mapagent/index.html
>> Click "Resource" (top-left) and "SetResource" (bottom-left)
>> On the right, enter the full path of the target WebLayout, eg.:
>> Library://myfolder/mylayout.WebLayout
>> Browse the "Content" file, and select the xml file.
>> Click "Submit".
>> 2. Download Maestro:
>> http://trac.osgeo.org/mapguide/wiki/maestro
>> You have 2 options:
>> a) Create a new WebLayout.
>> Click "Edit Xml" (button on the top toolbar)
>> Paste your new xml into the box.
>> Click "OK"
>> Click the "Save" icon (button on the top toolbar)
>> b) Create a new WebLayout
>> Save it.
>> Right click it, and select "Load from Xml"
>> stoff skrev:
>>> Hi,
>>> where do I find the target XML File? Where can I place the a new modified
>>> XML File to be reloaded by MapGuide Studio...?
>>> Bes regards,
>>> stoff
>>>> then merge the toolbox/contextmenu/task sections from the source XML
>>>> file
>>>> into the target XML, then reload the modified XML file for the layout
>>>> onto
>>>> the target server.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080817/27824381/attachment.html
