[mapguide-users] Create layer from oracle database without spatial data
Rahul unicorn_admirer at yahoo.com
Sun Aug 17 23:31:35 EDT 2008
     Check about the Spatial Index as well as the Primary Key ,infact you can try Fdo2Fdo's Oracle Toolbox for the same.
Max !
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Friday, August 15, 2008 5:43:42 PM
Subject: Re: [mapguide-users] Create layer from oracle database without spatial data
Thanks very much for your help here.
We finally build the oracle spatial data.
However, we still got the same problem: the layer whatever created by oracle
view or oracle spatial data, it can not be select.
The selection property is correct, but i cant select item ex: building ,
landmark.....
What should I do to make the layer  selectable as the layer create by shp
file?
T.H. Yu.
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18996760.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080817/7337f75b/attachment.html
