[mapguide-users] UnManagedData Slow
Rock Beans rockbeans at gmail.com
Tue Aug 19 16:15:30 EDT 2008
Unmanaged is separate from pooling as pooling was a work around to
speed things up when unmanaged was broke. Pooling works on managed and
unmanaged data. Looking back it really did not help the issue at all.
I have heard unmanaged shp (multiple within one folder) is still an
issue though I have yet to prove that. I would also love confirmation
that we can start dumping 20-40 shp files in one aliased folder to
eliminate the need for load procedures and multiple feature sources.
The Rock
On Tue, Aug 19, 2008 at 11:20 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Was this issue resolved? Are SDF and SHP safe to pool?
> On Tue, Jul 10, 2007 at 2:43 AM, Bruce Dechant
> <bruce.dechant at autodesk.com> wrote:
>> SDF and SHP are excluded from pooling because of an update/reader issue
>> within FDO that has not been addressed yet.
>> If you notice some problems with update/readers then you should leave it
>> as excluded. I believe this is planned to be fixed with the next release
>> of FDO post MGOS 1.2.
>> Thanks,
>> Bruce
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nichols,
>> David
>> Sent: July 5, 2007 10:23 AM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] UnManagedData Slow
>> That did it!!  Thanks.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
>> Morsell
>> Sent: Thursday, July 05, 2007 11:32 AM
>> To: 'MapGuide Users Mail List'
>> See this existing trac ticket on this topic:
>> http://trac.osgeo.org/mapguide/ticket/175.  If you enable pooling for
>> SDF (I believe SDF by default is excluded from pooling in
>> serverconfig.ini) you should see the same performance increase noted in
>> the ticket.  The development team is aware of these issues and have set
>> the milestone for this to be fixed in release 1.3
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nicholda
>> Sent: Thursday, July 05, 2007 5:58 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] UnManagedData Slow
>> Hi all,
>> I hope someone can point me in the right direction, I am using 1.2 and
>> have re-mapped data to a location on disk.  I am seeing a noticeable
>> difference in response time between managed and unmanaged data.  I
>> re-mapped my feature source as shown below.
>> Original
>> <?xml version="1.0" encoding="utf-8"?>
>> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>  <Provider>OSGeo.SDF</Provider>
>>  <Parameter>
>>    <Name>File</Name>
>>    <Value>>%MG_DATA_FILE_PATH%AsBuiltBldgs.sdf</Value>
>>  </Parameter>
>>  <Parameter>
>>    <Name>ReadOnly</Name>
>>    <Value>TRUE</Value>
>>  </Parameter>
>> </FeatureSource>
>> Modified
>>  <Parameter>
>>    <Name>File</Name>
>>    <Value>E:/FME_Data/mgos/AsBuiltBldgs.sdf</Value>
>>  </Parameter>
>>  <Parameter>
>>    <Value>FALSE</Value>
>>  </Parameter>
>> </FeatureSource>
>> After re-mapping I added the following alias to the serverconfig.ini
>> file.
>> [UnmanagedDataMappings]
>> UnmanagedSdf = E:\FME_Data\mgos
>> I then used the EnumerateUnmanagedData API to get the following.  But I
>> am not sure what to do next.
>>  <?xml version="1.0" encoding="UTF-8"?> <UnmanagedDataList
>> xsi:noNamespaceSchemaLocation="UnmanagedDataList-1.0.0.xsd">
>>        <UnmanagedDataFile>
>> <UnmanagedDataId>[UnmanagedSdf]AsBuiltBldgs.sdf</UnmanagedDataId>
>>                <CreatedDate>2007-06-28T13:00:40Z</CreatedDate>
>>                <ModifiedDate>2007-06-28T13:00:40Z</ModifiedDate>
>>                <Size>563200</Size>
>>        </UnmanagedDataFile>
>> </UnmanagedDataList>
>> Am I on the right track for improved performance/response time or am I
>> completely off base.  Any suggestions are welcomed.
>> Thanks,
>> David
>> View this message in context:
>> http://www.nabble.com/UnManagedData-Slow-tf4029540s16610.html#a11445964
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> This footnote confirms that this email message has been scanned by
>> PineApp Mail-SeCure for the presence of malicious code, vandals &
>> computer viruses.
>> computer viruses.
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
