[mapguide-users] Fusion Overview widget - thicker line?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Aug 19 16:37:03 EDT 2008
Already done...
Jason Birch wrote:
> I’d strongly recommend cloning one of the templates for your own use
> unless you are pulling your templates from MGOS SVN.
> This will allow you to use something like Beyond Compare or WinMerge
> to compare to the original when upgrading.
> Jason
> *From:* Andrew DeMerchant
> *Subject:* Re: [mapguide-users] Fusion Overview widget - thicker line?
> Ah, but I'm using Maestro / Studio - so there's not html for me to
> edit. The change I make will have to be at the template level, or the
> widget itself...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
