[mapguide-users] MGOS 2.0.1 Crash Issues
Maksim Sestic max at geoinova.com
Thu Aug 21 03:45:41 EDT 2008
Just a side note: identical bugs are present in MGE too (2007, 2008 and
2009) running on IIS / .NET. Maybe this hint helps pinpointing the source of
all this.
Regards,
Maksim Sestic
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, August 21, 2008 05:55
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MGOS 2.0.1 Crash Issues
Kenneth,
It looks like by default, MGOS 2.0.1 has the following line in
serverconfig.ini:
DataConnectionPoolSizeCustom = OSGeo.Gdal:1,Autodesk.Raster:1
So, it looks like everyone is using a pool size of 1 for the raster
providers already.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Sunday, August 17, 2008 12:23 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS 2.0.1 Crash Issues
Have you tried to add the provider(s) as having a connectionpoolsize of one?
(in serverconfig.ini)
It is bound to give really bad performance, but it may give stability.
If it gets stable with only one connection, the issue is likely a threadding
problem in MG or the provider.
Regards, Kenneth Skovhede, GEOGRAF A/S
nclayton skrev:
Something else I forgot to mention, thanks for bringing that up Andy!
I'm running IIS / PHP and using MySQL for the backend (using odbc
connections instead of mysql connections)
Andy Morsell wrote:
I have similar crashing problems with 2.0.1 and also suspect raster
issues,
although there are no clues in the error or event logs about this.  The
reason I suspect raster issues is that when things start to go wonky, maps
with no raster work for a little while maps with raster fail to render.
Eventually, mgserver faults and locks up.
The one common denominator for those with instability issues seems to be
running MGOS with IIS / .NET.  Is that the case for all with these
problems?
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, August 14, 2008 8:37 AM
how do they perform if you remove the rasters ?
On Fri, Aug 15, 2008 at 1:23 AM, nclayton  <mailto:nclayton at gmail.com>
<nclayton at gmail.com> wrote:
The old server is no longer in use so I can't give specifics on its
specs.
The new box is:
Windows 2003 Server Standard Edition SP2
2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
Application Pool)
4GB RAM
Attached is my serverconfig.ini file. I didn't make many changes to it,
other than changing the repository paths. I honestly am not 100% sure of
what effects most of the settings have on the system.
Here's a list of the currently available urls in case someone might can
see
something I've done in the maps that could cause some of my problems:
http://www.tscmaps.com/mapguide/mapviewer/?state=ms
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest>
&county=forrest
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette>
&county=lafayette
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee> &county=lee
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes>
&county=lowndes
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha>
&county=oktibbeha
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower>
&county=sunflower
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica>
&county=tunica
<http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston>
&county=winston
They all use the same layer styles...I just copy the layers to a new
county
folder, change where the file points to and add it to a new county map.
Each
county has a set of ECW raster files.
zspitzer wrote:
can you describe the specs of the two machines ?
had you tweaked the serverconfig.ini for the size of the machine?
On Fri, Aug 15, 2008 at 12:22 AM, nclayton  <mailto:nclayton at gmail.com>
yeah, I had that in place. It's odd that some of these errors only
started
happening on this new box which has a lot more horsepower than the
previous
one.
i'm going to keep mgos installed and try to do some testing to try to
figure
out what exactly is causing things to die on me.
Rock Beans wrote:
That is to bad. It might have been something easy to fix. Was you
installation patched to fix the Firefox 3 crash bug?
The Rock
On Thu, Aug 14, 2008 at 8:53 AM, nclayton  <mailto:nclayton at gmail.com>
Sadly, due to the constant crashes I am having to revert all of our
maps
back
to mapguide 6.3
hopefully things will smooth out more in future releases.
View this message in context:
http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080821/2066a5b0/attachment.html
