[mapguide-users] Fusion + Oracle datasource problem
gingerbbm stuart.jones at jacobs.com
Thu Aug 21 12:33:40 EDT 2008
Rock Beans wrote:
> To be honest how does the data source type affect one viewer over the
> other
It's simply the problem that startup takes an age - if it works at all. And
with more than ten or so layers it simply doesn't work. But it's true that
if and when the initial load is done it all works fine. And that's the
galling part.
View this message in context: http://www.nabble.com/Fusion-%2B-Oracle-datasource-problem-tp17884373p19092385.html
