[mapguide-users] Fusion - how to set min zoom level?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Aug 22 12:24:49 EDT 2008
I don't have defined scales for my map. I have an initial view location
- In my case, AJAX most certainly does _not_ act like Fusion. In AJAX,
my map loads at 1:147716.....I can use the zoom slider to zoom out to
1:4947533 (plenty far!). In Fusion, it loads at 1:146319, but like I
say, the zoom slider is all the way at the bottom...I can't zoom out
anymore. I can't even type in a new scale manually...
Andrew
Maksim Sestic wrote:
> Andrew,
> AJAX acts in the same way if you have fixed set of scales defined for a map.
> Regards,
> Maksim Sestic
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
> DeMerchant
> Sent: Friday, August 22, 2008 17:57
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Fusion - how to set min zoom level?
> Thanks - but I know how to set my initial view. I just want to be able to
> zoom out more, beyond that initial view. Right now, in Fusion (not in AJAX
> or DWF) I can't zoom out past my initial view.
> Andrew
> Rodolfo Moreno wrote:
>> I suposse that you are using studio 2009, well first you must define
>> an extent greater that your layers.
>> These values are accordign to your preference. It depends that how
>> many you want to zoom out.
>> Next you have that setting the map widget located in your flexible layout.
>> Choose the radio button option "use custom view" and place the scale
>> and the center coordinates of you preference. These values will
>> determine the initial zoom.
>> Regards
>> Andrew DeMerchant wrote:
>>> In my Fusion maps, I've just noticed that I can't zoom out beyond my
>>> initial map view. The zoom slider starts out at the bottom - this
>>> happens on all of my Fusion layouts. How do I set a different zoom
>>> out max limit (using Studio / Maestro)?
>>> Andrew
>>> 	*Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited<http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Rodolfo Moreno
>> CivilEng
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> database 2888 (20080220) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> http://www.eset.com
	*Andrew DeMerchant*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
