[ZS1] RE: [mapguide-users] Present postgis data with unknowncoordinatesystem
Andre Schoonbee andresch at iway.na
Sun Aug 24 16:17:22 EDT 2008
Hi Kenneth
Ticket 677 has been logged:
Andre
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Sunday, 24 August, 2008 3:39 PM
To: MapGuide Users Mail List
Subject: Re: [ZS1] RE: [mapguide-users] Present postgis data with
Could you create a bug report regarding the MgDbXmlException:
http://trac.osgeo.org/mapguide/newticket
Before pressing "Save", click the "Edit Xml" button.
Select all the text and attach that to the bug report, and I will try to fix
it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andre Schoonbee skrev:
It seems the problem is not the coordinate system
I have loaded the postgis data using Quantum GIS and the data is in WGS84.
So even when specifying the EPSG:34326, still does not display anything, not
as a layer or as a map.I am using Maersto version (r3285), to create a
standard Ajax map.
But when I want to define the style for the towns point feature, I get an
error:
An error occurred while saving: The remote server returned an error: (559)
MgDbXmlException.:
An exception occurred in DB XM component.
Error: XML Indexer: Parse error in document at line, 45 char22, Parser
message: Element ' BackgroundColor' is not valid content model:
Exception occurred in method MgResourceDefinitionManager.UpdateDocument at
line 601 in file
d:\buildforgeprojects\mapguide_opensource_v2.0\build_27.16\mgdev\derver\src\
services\resource\ResourceDefinitionManage.cpp
Andre
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Sunday, 24 August, 2008 6:38 AM
Subject: Re: [mapguide-users] Present postgis data with unknown
coordinatesystem
try overriding the co-ordinates system picking a common one like epsg:4326
http://spatialreference.org/ref/epsg/4326/
you imply that individual layers work fine by themselves?
no errors in the server error log?
are you using fusion or the basic layouts?
z
On Sun, Aug 24, 2008 at 6:58 AM, Andre Schoonbee  <mailto:andresch at iway.na>
<andresch at iway.na> wrote:
I have data in a postgis Database. I do not know in what coordinate system
the data is. When I triy to render the layers on a map, I got  a blank
map.
I assume the problem is the coordinate system error.
What should I do?
Andre
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
__________ Information from ESET Smart Security, version of virus signature
database 3382 (20080823) __________
The message was checked by ESET Smart Security.
http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080824/22b7a013/attachment.html
