[mapguide-users] Changing the Scale and Extents of a MgMap via .NETAPI
Maksim Sestic max at geoinova.com
Tue Aug 26 04:40:40 EDT 2008
Hi Nothi,
Please see the following example:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
Regards,
Maksim Sestic
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Johann
Nothbauer
Sent: Friday, August 22, 2008 14:25
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Changing the Scale and Extents of a MgMap via
.NETAPI
Hi All!
Is it possible to manipulate a MgMap object via the .NET API?
I am using the .NET API without a Viewer-Context. I'm trying to render a Map
to a System.Windows.Form in .NET.
I can render a Map, but can I can't change the ViewExtents or the ViewScale
like this:
MgMap kgMap = new MgMap();
... some map initialization...
MgPoint center = kgMap.ViewCenter;  // this works well double viewScale =
kgMap.ViewScale;
kgMap.SetViewScale() // is impossible, no such Method
Is this the right approach for doing such things?
Should I use the Mapagent instead? If yes, which Method will do the Trick?
cheers,
Nothi
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3387 (20080826) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
http://www.eset.com
