[mapguide-users] Is there a file size limit?
BradM masonb at dfo-mpo.gc.ca
Tue Aug 26 16:48:15 EDT 2008
Yes we turned all other layers off and even tried removing them completely.
This is a line layer and double line layer for rivers and polygon layer for
lakes. So it is a mix of several layers. Yes there is labelling but we
turned it off to try to speed things up.  We just increased the cache size
in the ini file and this seems to have helped with speed but it is still
very slow when we select a stream to get its properties.  I don't know which
line style is being used, I will have to get back to you on that question.
thanks
brad
Traian Stanev wrote:
> There is no size limit. To make sure this layer is to blame, did you turn
> off all other layers when viewing the map? Also, is this a line layer or a
> polygons layer. What line style or polygon style is it using to render? Is
> there labeling?
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of BradM
>> Sent: Tuesday, August 26, 2008 4:15 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Is there a file size limit?
>> After upgrading from MGE2008 to MGE2009 we have noticed a severe
>> decline in
>> map rendering speed for our hydrology layer for British Columbia.  The
>> sdf
>> file is about 800megs and is in the map repository. Is there a file
>> size
>> limit?  We have tried to optimize the server to improve speeds with no
>> success. Any suggestions welcomed.
>> View this message in context: http://www.nabble.com/Is-there-a-file-
>> size-limit--tp19169522p19169522.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Is-there-a-file-size-limit--tp19169522p19170081.html
