[mapguide-users] invokeURL FUSION only works fine from mgstudio
Rodolfo Moreno rmoreno at voxiva.com
Wed Aug 27 11:12:02 EDT 2008
Hi Chris,
I am sending the xml of my flexible layout. you have to launch the map from
the index.html file in order to get the error that I mentioned.
Chris Claydon wrote:
> Can you save your flexible web layout as XML and send it to us? (MG Studio
> has a function to save as XML) I'd like to try to reproduce the problem.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Tuesday, August 26, 2008 4:33 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] invokeURL FUSION only works fine from mgstudio
> I am using an invokeURL widget. When my map is launched from mapguide
> studio
> 2009 the SESSIONID and MAPNAME parameters are sent without errors to the
> mapguide server, however when the map is launched from the index.html
> directly these parameters are sent twice.
> Request["MAPNAME"] = MyMap48b483ff318e5,MyMap48b483ff318e5
> is it a issue of fusion?
> Regards
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/invokeURL-FUSION-only-works-fine-from-mgstudio-tp785418p785418.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/n787259/VentanillaFlexibleLayout.ApplicationDefinition.xml
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/invokeURL-FUSION-only-works-fine-from-mgstudio-tp785418p787259.html
