[mapguide-users] Manipulating Maps in a Session, .NET API
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Aug 27 13:05:22 EDT 2008
I have not used tiles, so I don't know how that is done.
If you just want to create tiles, Kori Maleski has done a great job with
a builder:
http://www.websoftdev.com/download.cfm
I'm guessing that tile (0,0) is has the same upper left coordinates as
your map extent.
Regards, Kenneth Skovhede, GEOGRAF A/S
Johann Nothbauer skrev:
> Hi Kenneth!
> Thanks for your clarification.
> I assume this is true for the Tile Service, as well?
> How can I find out, which Tile (Row/Column) should be fetched for a
> certain World Coordinate? I know how to compute the Tile Size in World
> Coordinates for the current scale. But where do the Tiles "Start"?
> Where is Tile 0/0 georeferenced? Is it the starting Map Extent?
> Any help appreciated,
> cheers,
> Nothi
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There is no scale in the runtime map (MgMap).
>> When you request that the image is rendered, you supply dpi,
>> resolution and either center/scale or extent.
>> You cannot store the scale or the center in the runtime map, you must
>> store it locally in your client.
>>> Hi All!
>>> Is it possible to manipulate a MgMap object via the .NET API?
>>> I am using the .NET API without a Viewer-Context. I'm trying to
>>> render a Map to a System.Windows.Form in .NET.
>>> I can render a Map, but can I can't change the ViewExtents or the
>>> ViewScale like this:
>>> MgMap kgMap = new MgMap();
>>> ... some map initialization...
>>> MgPoint center = kgMap.ViewCenter;  // this works well
>>> double viewScale = kgMap.ViewScale;
>>> kgMap.SetViewScale() // is impossible, no such Method
>>> Is this the right approach for doing such things?
>>> Should I use the Mapagent instead? If yes, which Method will do the
>>> Trick?
>>> cheers,
>>> Nothi
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
