[mapguide-users] MGE2009 crashing
Maksim Sestic max at geoinova.com
Fri Aug 29 03:14:14 EDT 2008
Brad, Andy,
MGE is a MGOS snapshot, plus commercial Autodesk FDO providers. I guess
there's nothing more or less with regards to MG server. The "tricky" part is
that Autodesk's chained client (Map 3D) needs to get upscaled to common FDO
version, too. Also - don't forget about Topobase, since it uses Map on
client side. But I'm not working for Autodesk and I believe their policy is
not to comment on release dates.
Regards,
Maksim Sestic
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Friday, August 29, 2008 02:41
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MGE2009 crashing
Brad,
No, I am not aware of a patch for MGE.  Perhaps the Autodesk folks can chime
in here.  If there is a patch forthcoming for MGE2009, we should see
something on the MGOS side first, however.......
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
Sent: Thursday, August 28, 2008 3:42 PM
To: mapguide-users at lists.osgeo.org
Hi Andy, I heard that there is a patch or fix coming out for MGE2009.  Are
you aware of it or when it may come?
thanks
Andy Morsell wrote:
> So it looks like it's not web server or web extension specific.  I
> agree since whenever I see problem there is a Windows error dialog on
> the console reporting mgserver.exe as the faulting module.  The only
> commonality here is that everyone reporting this problem is running
> Windows.  Is anyone running MGOS 2.0.1 on Linux in a production
> environment seeing these same problems?
> By the way Zac, your openlayers demo is very cool.
> Andy
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac
> Spitzer
> Sent: Thursday, August 28, 2008 8:40 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGE2009 crashing
> server is down it's the  /. effect
> I am seeing this on XP/2003 with Apache and php / java as well. I
> think the problem lies in the mgserver side rather than anything in
> the webtier.
> 2.0.1 is still not stable enough, using tiled maps helped a lot, but
> it's still a gamble.
> I ended up developing a workaround which involves bypassing the
> MapGuide server altogether for tiled maps, using openlayers and a
> static copy of a fully seeded tile cache.
> here's a demo, that's just plain old apache
> http://ennoble.dreamhosters.com/maps/tm-kl/
> z
> On Fri, Aug 29, 2008 at 1:05 AM, BradM <masonb at dfo-mpo.gc.ca> wrote:
> We are using Apache.  The watershed atlas and its tool tips seem to be
> causing the server to choke:
> http://204.244.79.12/mapguide2009/SHIM/Shim.php
> Andy Morsell wrote:
>> That's very similar to the thread I started yesterday regarding
>> crashing problems I'm having with MGOS 2.0.1.  I am seeing the same
>> error messages in the log files.  Are you using Windows Server / IIS
>> / .NET?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> Sent: Thursday, August 28, 2008 7:53 AM
>> Subject: [mapguide-users] MGE2009 crashing
>> Our server crashed again last night.   Is more ram a possible solution?
>> We
>> did not have this problem with MGE2008 thanks
>> <2008-08-27T14:36:56>    Anonymous
>>  Error: Out of memory.
>>         bad allocation
>>  StackTrace:
>>   - MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\
>> rendering\RenderingServiceHandler.cpp
>>   - MgOpQueryFeatures.Execute line 125 file
>> rendering\OpQueryFeatures.cpp
>>   - MgServerRenderingService.QueryFeatures line 647 file
>> rendering\ServerRenderingService.cpp
>>   - MgServerRenderingService.RenderForSelection line 1252 file
>> Out of memory.
>> bad allocation
>> View this message in context:
>> http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MGE2009-crashing-tp19202309p19202572.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
http://www.nabble.com/MGE2009-crashing-tp19202309p19210635.html
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3395 (20080828) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
