[mapguide-users] LatLong to UTM
Dave Wilson dave.wilson at autodesk.com
Fri Aug 29 13:32:50 EDT 2008
Using MGE2009 I get the correct answer for your Zone 12 example. The difference may be related to PROJ4 vs Mentor being used in MGOS. Which version of MGOS?
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Don MacGregor
Sent: Friday, August 29, 2008 10:46 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] LatLong to UTM
Hi Dave,
You are right the point was in Zone 19.
But even when I enter a zone 12 point e.g. Long -110.85980508, Lat
55.50472355 then I got N:6151000.496561 E:508855.1818729 as a result and the
point should be N:6150967.822 E:508855.135.
Many thanks for you time.
Dave Wilson-3 wrote:
> I could be completely off here, but -71,42 is in North Eastern United
> States which is definitely not Zone 12.
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Don C.
> MacGregor
> Sent: Friday, August 29, 2008 8:32 AM
> Subject: [mapguide-users] LatLong to UTM
> Hi folks,
> I am trying to write a script that can convert LatLong point to UTM.
> Although the script its working but I am not getting the right results.
> Below please find my script.
>     $wktProj =
> 'PROJCS["NAD_1983_UTM_Zone_12N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-111.0],PARAMETER["Scale_Factor",0.99965242],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]';
>         $coordSysFactory = new MgCoordinateSystemFactory();
>         $coordSysProj = $coordSysFactory->Create($wktProj);
>         $geometryFactory = new MgGeometryFactory();
>         $xProj = -71.061342;
>         $yProj= 42.353966647205;
>         $coordinate = $geometryFactory->CreateCoordinateXY($xProj,
> $yProj);
>         $convertedCoordinate =
> $coordSysProj->ConvertFromLonLat($coordinate);
>         $xConv = $convertedCoordinate->GetX();
>         $yConv = $convertedCoordinate->GetY();
> I am getting (434696.747152, 6017918.57788) and the correct porjected
> point is (434700.172, 6017603.009).
> Any help in this regard would be highly appreciated.
> Thanks
> ________________________________
> [http://us.i1.yimg.com/us.yimg.com/i/ca/iotg_search.jpg]Yahoo! Canada
> Toolbar : Search from anywhere on the web and bookmark your favourite
> sites. Download it now! <http://ca.toolbar.yahoo.com/>
> mapguide-users mailing list
View this message in context: http://www.nabble.com/LatLong-to-UTM-tp19221187p19223605.html
