[mapguide-users] XML Parser error for Feature Sources
cagray colin.gray at 1spatial.com
Mon Dec 1 06:30:50 EST 2008
I have a web application in .NET c# which allows a user to define their own
feature sources and set the connection parameters. It is very similar to
doing the same through map guide's own interface. However no matter I do to
the xml in the code behind I get the error:
An exception occurred in the XML parser.
this gives me no detail why so is very hard to debug. I have validated the
xml against the xsd and it validates fine. Example of xml below:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.SHP</Provider>
  <Parameter>
    <Name>DefaultFileLocation</Name>
    <Value>d:\Data\OLPSample_EDC\Local Plan\Lines_ polygon\economic
development opportunities.shp</Value>
  </Parameter>
</FeatureSource>
My method is to grab the xml from mapguide as:
            XmlDocument xmlDoc = new XmlDocument();
            xmlDoc.PreserveWhitespace = true;
            string strXml =
resourceService.GetResourceContent(resourceID).ToString();
            xmlDoc.LoadXml(strXml);
Then I traverse the xml structure and edit node's InnerText or add nodes as
appropriate. Once done I do:
	MgByteSource byteSource = getResourceByteSource(xmlDoc);
	MgResourceIdentifier resourceID = new MgResourceIdentifier(whereToString +
"//" + resourceName + "." + resourceType);
	resourceService.SetResource(resourceID, byteSource.GetReader(), null);
where the getResourceByteSource function looks like:
public MgByteSource getResourceByteSource(XmlDocument xmlDoc)
            MemoryStream memStream = new MemoryStream();
            xmlDoc.Save(memStream);
            Byte[] arrBytes = memStream.ToArray();
            UTF8Encoding utf8 = new UTF8Encoding();
            byte[] encodedDefinition =
utf8.GetBytes(xmlDoc.InnerXml.ToString());
            MgByteSource contentByteSource = new
MgByteSource(encodedDefinition, encodedDefinition.Length);
            return contentByteSource;
This works completely find for editing layer definitions but no matter what
I do with feature source xml it returns this error. I have tried hand coded
xml strings, adding spaces, removing formatting etc. I even have tried just
taking a feature resource straight out and trying to put it back without any
changes and this error still occurs.
Anyone ever seen this before (and hopefully got round it)?
Thanks
Colin
View this message in context: http://www.nabble.com/XML-Parser-error-for-Feature-Sources-tp20770245p20770245.html
