[mapguide-users] XML Parser error for Feature Sources
cagray colin.gray at 1spatial.com
Mon Dec 1 08:26:03 EST 2008
Thanks for the reply. Unfortunately that did not solve my problem and I got
the same error. Is there anything else I could try?
I was not aware you could do this without generating/manipulating the xml.
My web tool has to fully control setting up data sources. So the user
selects a provider and then fills in the connection details. I then need to
create a new data source from this to be stored in mapguide. Can you do this
using the Meastro API alone?
Kenneth Skovhede, GEOGRAF A/S wrote:
> I believe the problem is the .Net UTF-8 Encoder prefixes an UTF-8 BOM,
> which causes problems in the Xml parser:
> http://trac.osgeo.org/mapguide/ticket/233
> You can try to create the UTF-8 encoder with:
> UTF8Encoding utf8 = new UTF8Encoding(false);
> And see if the problem goes away.
> Alternatively you can use the MaestroAPI instead of messing with the raw
> Xml:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
> Regards, Kenneth Skovhede, GEOGRAF A/S
View this message in context: http://www.nabble.com/XML-Parser-error-for-Feature-Sources-tp20770245p20771868.html
