[mapguide-users] SV: Runtime map problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Dec 3 05:05:07 EST 2008
i tried ur updated version of code
my code was
        Dim host As New
Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
        Dim conn As New HttpServerConnection(host, "Administrator", "admin",
"en", True)
        'You have to change the string below to point at a valid WebLayout
        Dim weblayout As WebLayout = conn.GetWebLayout("Library://Filebased
data/Layout/layout.WebLayout")
        Dim mapdefinition As MapDefinition =
conn.GetMapDefinition(weblayout.Map.ResourceId)
        'Modify the initial view of the weblayout
        weblayout.Map.InitialView = New MapViewType()
        weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
        weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
        weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
        'Obtain a unique session based id for the temporary weblayout (which
is a copy of an existing WebLayout)
        Dim tempid As ResourceIdentifier = New
ResourceIdentifier(Guid.NewGuid().ToString(),
OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
        'Save the layout, otherwise you can't reference it
        conn.SaveResourceAs(weblayout, tempid)
        'Open the viewer, and use the temporary layout, since the map only
exists in the
        'current session, we must use that session, and NOT supply
username/password
        'BEWARE: The session belongs to the Administrator account, so the
user gets full access to MapGuide (delete, modify, etc.)
        Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
Server.UrlEncode(tempid) & "&SESSION=" & Server.UrlEncode(conn.SessionID))
but i got an error that
Server Error in '/maestro' Application.
HTTP Error 404 - Not Found.
Version Information: ASP.NET Development Server 8.0.0.0
i think this maybe with "data not found" problem
but i have an Filebased data package in the
C:\program files\mapguide opensource 2.0\server\packages
1) then what will be the problem?
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I wrote a follow up, with corrected code.
> You are using the initial one, and you are missing a "?" mark in the
> redirect URL.
> Try to use the updated version, and beware of the question mark in the
> Response.Redirect call.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for u r reply.
>> I tried this code but i got an error that
>> HTTP Error 400 - Bad Request.
>> my code was
>>     Dim host As New
>> "admin",
>> "en", True)
>> WebLayout
>> ResourceIdentifier("layout",
>>         Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>> joscsu wrote:
>>>  Or this:
>>> System.Guid.NewGuid().ToString()
>>> ----- Ursprungligt meddelande ----
>>> Från: Maksim Sestic <max at geoinova.com>
>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>> Skickat: tisdag 2 december 2008 16:49:21
>>> Ämne: RE: [mapguide-users] Runtime map problem
>>> Try this:
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>> godavarthi
>>> Sent: Tuesday, December 02, 2008 15:35
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: Re: [mapguide-users] Runtime map problem
>>> Hi,
>>> Thanku very much for ur help
>>> i tried this code
>>> but i got an error in the line
>>> Dim tempid as ResourceIdentifier = new
>>> ResourceIdentifier(Guid.NewGuid(),
>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>> because of this Guid.NewGuid()
>>> 1) Actually what is this?
>>> 2) Which paramater we have to pass in this place instead of
>>> Guid.NewGuid()
>>> Regards,
>>> Padmini
>>>> I forgot to save the weblayout in the code below :(
>>>> Updated version is:
>>>> 'Setup connection
>>>> Dim host As New
>>>> "en", True)
>>>> 'You have to change the string below to point at a valid WebLayout Dim
>>>> weblayout as WebLayout =
>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>> Dim mapdefinition as MapDefinition =
>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView =
>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>> 1:2000 weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX
>>>> is a copy of an existing WebLayout) Dim tempid as ResourceIdentifier =
>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>> con.SaveResourceAs(weblayout, tempid)
>>>> exists in the 'current session, we must use that session, and NOT
>>>> supply username/password
>>>> 'BEWARE: The session belongs to the Administrator account, so the user
>>>> Server.UrlEncode(con.SessionID))
>>>> Kenneth Skovhede, GEOGRAF A/S skrev:
>>>>> To build a map, you must have all the components:
>>>>> 1. FeatureSource, references data
>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>> MapDefinition
>>>>> All these items must be in a repository (either Library or Session),
>>>>> otherwise they can't be referenced.
>>>>> When you write that you want to "create a WebLayout programatically",
>>>>> do you want to create ALL the above items, or do you have layers and
>>>>> featuresources?
>>>>> (1) If you want to generate a WebLayout ResourceID, you should use:
>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>> ResourceTypes.WebLayout)
>>>>> If you want to read the name of an existing MapDefinition from
>>>>> another layout, you must do:
>>>>> Dim weblayout as WebLayout =
>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>> (2) I don't understand the question.
>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>> layers, which references featuresources, as described above. It is
>>>>> very slow to do this, so when you open a map in the browser, the xml
>>>>> is transformed into a binary object. This object contains all the
>>>>> info from the MapDefinition and some info from the layers and
>>>>> featuresources.
>>>>> You need to know this, because if you try to toggle layer visibility
>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map is a
>>>>> binary object that you can manipulate using the MapGuide (and
>>>>> Maestro)-API, and it only works for a displayed map.
>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>> was created from.
>>>>> A short example of using an existing WebLayout:
>>>>> Dim host As New
>>>>> "en", True)
>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim tempid
>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>> Hi,
>>>>>> actually i wrote the code as
>>>>>>     Dim host As New
>>>>>> "admin", "en", True)
>>>>>> data/Maps/mapdata",
>>>>>> ResourceTypes.MapDefinition)
>>>>>>         Dim mapId As String = res.ResourceId
>>>>>> with that i got the map resource id.
>>>>>> But actually to run the application the url in the browser must be
>>>>>> like
>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>> 1) How can i get this weblayout (like
>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>> programmetically
>>>>>> 2) I want to redirect to the ajax viewer sample application through
>>>>>> asp.net (like given by u )
>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>> for
>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>> configusing
>>>>>> state)
>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>> explain what parts of my previous reply that are unclear or wrong?
>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>> 704038.html#a20769349
>>>>>>>>   Hi ,
>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1) Iam
>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>> observed that the layout path given in the application.
>>>>>>>> as
>>>>>>>> String webLayout =
>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>   it works but now i want to create this weblayout in run time (by
>>>>>>>> code)
>>>>>>>> using mapguide maestro api
>>>>>>>> for this purpose i followed the link
>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>> timeMap
>>>>>>>> but i didnt get any out.
>>>>>>>> can u plz tell me
>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>> 2) How it will works
>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature
>>> database 3658 (20081202) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>>       __________________________________________________________
>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20809998.html
