[mapguide-users] Runtime map
padmini godavarthi godavarthi.padmini at gmail.com
Fri Dec 5 04:45:03 EST 2008
hi,
thanks for ur reply.
but i didnt get u.
can u explain me briefly.
Thanks and Regards,
Padmini
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you are using the AJAX, DWF or Fusion viewer only,
> you probably never want to create a runtime map.
> The official viewers create the runtime map for you.
> (and overwrite any you have created).
> In that situation, you will need to load the current runtime map from
> the repository,
> modify it, save it, and refresh the client.
> You would the pass the SessionID to your ASPX code, and
> open the connection using:
> conn = new HttpServerConnection(host, sessionId, "en", True)
> Then you will load the runtime map (delete the create call):
> Dim rtMap As RuntimeClasses.RuntimeMap = conn.GetRuntimeMap(rtMapId)
> Modify it, eg:
>  rtMap.Layers(0).Visible = False
> and Save it:
> conn.SaveRuntimeMap(rtMap);
> Then in javascript do:
> GetMapFrame().Refresh();
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> iam using mapguide opensource 2.0(.net 2.0 +IIS 5.1).
>> i saw the runtime map sample application in the url
>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>> according to the sample application i changed my code as
>>                Dim host As New
>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>         Dim conn As New HttpServerConnection(host, "Administrator",
>> "admin",
>> "en", True)
>>         Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>> ResourceTypes.MapDefinition)
>>         Dim mapId As String = res.ResourceId
>>         Dim mapDef As MapDefinition = conn.GetMapDefinition(mapId)
>>         Dim mapName As String = res.Name
>>         Dim rtMapId As String = New ResourceIdentifier(mapName,
>> ResourceTypes.RuntimeMap, conn.SessionID)
>>         conn.CreateRuntimeMap(rtMapId, mapDef)
>> i didnt get this one
>> 1) What i have to do with this?
>> 2) What will be the output
>> If anybody knows me can u plz tell me the procedure
>> Regards,
>> Padmini
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Runtime-map-tp20830536p20850643.html
