[mapguide-users] Runtime map
padmini godavarthi godavarthi.padmini at gmail.com
Fri Dec 5 05:16:33 EST 2008
i dont know about the runtime map.
thats why iam waiting for someone to explain about the runtime map
Regards,
padmini
zspitzer wrote:
> what do you think a run time map is?
> On Fri, Dec 5, 2008 at 8:45 PM, padmini godavarthi
> <godavarthi.padmini at gmail.com> wrote:
>> hi,
>> thanks for ur reply.
>> but i didnt get u.
>> can u explain me briefly.
>> Thanks and Regards,
>> Padmini
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> If you are using the AJAX, DWF or Fusion viewer only,
>>> you probably never want to create a runtime map.
>>> The official viewers create the runtime map for you.
>>> (and overwrite any you have created).
>>> In that situation, you will need to load the current runtime map from
>>> the repository,
>>> modify it, save it, and refresh the client.
>>> You would the pass the SessionID to your ASPX code, and
>>> open the connection using:
>>> conn = new HttpServerConnection(host, sessionId, "en", True)
>>> Then you will load the runtime map (delete the create call):
>>> Dim rtMap As RuntimeClasses.RuntimeMap = conn.GetRuntimeMap(rtMapId)
>>> Modify it, eg:
>>>  rtMap.Layers(0).Visible = False
>>> and Save it:
>>> conn.SaveRuntimeMap(rtMap);
>>> Then in javascript do:
>>> GetMapFrame().Refresh();
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> padmini godavarthi skrev:
>>>> Hi,
>>>> iam using mapguide opensource 2.0(.net 2.0 +IIS 5.1).
>>>> i saw the runtime map sample application in the url
>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>>>> according to the sample application i changed my code as
>>>>                Dim host As New
>>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>>> "admin",
>>>> "en", True)
>>>>         Dim res As New ResourceIdentifier("Filebased
>>>> data/Maps/mapdata",
>>>> ResourceTypes.MapDefinition)
>>>>         Dim mapId As String = res.ResourceId
>>>>         Dim mapDef As MapDefinition = conn.GetMapDefinition(mapId)
>>>>         Dim mapName As String = res.Name
>>>>         Dim rtMapId As String = New ResourceIdentifier(mapName,
>>>> ResourceTypes.RuntimeMap, conn.SessionID)
>>>>         conn.CreateRuntimeMap(rtMapId, mapDef)
>>>> i didnt get this one
>>>> 1) What i have to do with this?
>>>> 2) What will be the output
>>>> If anybody knows me can u plz tell me the procedure
>>>> Regards,
>>>> Padmini
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Runtime-map-tp20830536p20850643.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://www.nabble.com/Runtime-map-tp20830536p20851069.html
