[mapguide-users] Draw a point,polgon
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Dec 8 11:50:22 EST 2008
You will need to use the FDO or similar access.
There exists javascript functions to digitize point/line/polygon.
Once done, you can send the digitized data to the server, and insert it
into a FeatureSource.
The "Buffer" code in the AJAX viewer shows how to insert such a feature
into a
temporary SDF FeatureSource. You can do the same with an existing database
or SDF FeatureSource.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks for u r reply.
> 1) I have an button for draw point and polygon
>  when i clicked on the map  some place a new point and polygon has to be
> drawn.
> How is it possible?
> Thanks and Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> How do you define new?
>> If you add it to the database, it will automatically be visible when the
>> map refreshes.
>>>    Hi iam using mapguide opensource  2.0(with .net 2.0 +IIS 5.1)
>>> My question is that
>>> 1) How to draw a new point,polygon on the map(either from database or
>>> normal) as a new layer
>>> If u knows plz help me
>>> Thanks and Regards,
>>> Padmini
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081208/3115c397/attachment.html
