[mapguide-users] Query features - Sheboygan package - other data
gsmith gregsmithb at gmail.com
Mon Dec 8 12:36:24 EST 2008
I am trying to get the query features task in the ajax viewer sample working
with another map resource I created in Maestro.
I modified the query.php based on suggestions in other threads to get it to
work with the Sheboygan package and mapguide 2.0. I can see the Sheboygan
map in the ajax viewer sample and can query features with results returned.
When I change the map resource for the SheboyganPhp layout, the map displays
successfully but the query features does not work. All off the
features/attributes list successfully in the task pane but when I hit
execute, nothing happens. The new map resource I am using is an OGR
dataconnection to an ESRI personal geodatabase.
The error log contains PHP Fatal error:  Uncaught exception
'mgnullargumentexception' in Unknown on line 0, referer:
http://localhost/mapguide/phpviewersample/query/querymain.php which is not
much help. I am not really sure where to start tackling this...
Mapguide 2.0.2.3011, Apache/2.2.4 (Win32) PHP/5.2.5 mod_jk/1.2.25
Thanks for the help
View this message in context: http://www.nabble.com/Query-features---Sheboygan-package---other-data-tp20899390p20899390.html
