[mapguide-users] Draw a point,polgon
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 9 02:28:25 EST 2008
C:\Program
files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewernet\buffer.aspx
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks
> 1) How tio use FDo
> can u give me the sample code
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You will need to use the FDO or similar access.
>> There exists javascript functions to digitize point/line/polygon.
>> Once done, you can send the digitized data to the server, and insert it
>> into a FeatureSource.
>> The "Buffer" code in the AJAX viewer shows how to insert such a feature
>> into a
>> temporary SDF FeatureSource. You can do the same with an existing database
>> or SDF FeatureSource.
>>> Hi,
>>> Thanks for u r reply.
>>> 1) I have an button for draw point and polygon
>>>  when i clicked on the map  some place a new point and polygon has to be
>>> drawn.
>>> How is it possible?
>>> Thanks and Regards,
>>> Padmini
>>>> How do you define new?
>>>> If you add it to the database, it will automatically be visible when the
>>>> map refreshes.
>>>>>    Hi iam using mapguide opensource  2.0(with .net 2.0 +IIS 5.1)
>>>>> My question is that
>>>>> 1) How to draw a new point,polygon on the map(either from database or
>>>>> normal) as a new layer
>>>>> If u knows plz help me
>>>>> Thanks and Regards,
>>>>> Padmini
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081209/36741419/attachment.html
