[mapguide-users] FeatureSet XML returned by QUERYMAPFEATURES for WFS layer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 9 07:28:04 EST 2008
You can press the "Edit Extensions" button to set up the primary key.
If no such "extensions" are entered, the datasource provides the
information.
In this case, you can't see it in Maestro.
You can use the DescribeFeatureSchema call to examine the setup of a
FeatureSource:
http://localhost/mapguide/mapagent/describeschemaform.html
More functions are avalible here:
http://localhost/mapguide/mapagent/index.html
Regards, Kenneth Skovhede, GEOGRAF A/S
gingerbbm skrev:
> Hi Kenneth
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You cannot select items from FeatureSources, if the FeatureSource has no
>> primary key.
> Could you elaborate on this a bit? If I look in Maestro at the XML for a WFS
> connector, or an SDF connector, or an Oracle connector, there's nothing to
> suggest a primary key. So how does MapGuide know whether one exists in a
> given data source?
> Thanks
> Stuart
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081209/8fd0e169/attachment.html
