[mapguide-users] FeatureSet XML returned by QUERYMAPFEATURES for WFS layer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Dec 9 09:33:06 EST 2008
The FDO provider exposes the datasource properties, including the
primary key setup.
How this is done depends on the provider.
For Oracle/MySQL/MSSql the info is extracted from
the table information.
I have found no documentation on configuring this manually,
and right now I can only refer you to the Maestro extension editor.
It does some heavy xml re-factoring, and is at least partly commented.
Regards, Kenneth Skovhede, GEOGRAF A/S
gingerbbm skrev:
> OK... any idea how I should configure the extension? Does MapGuide assume a
> particular extension name for primary keys?
