[mapguide-users] SDF convertion question
Nandorov nandorov at gmail.com
Thu Dec 18 15:32:16 EST 2008
Hi Jackie,
i download FDO Toolbox, but i can't connect to my .txt file.
I've configured the odbc connection, but when i try to make a connection
with the driver it fails.
my original connection string was
Driver={Microsoft Text Driver (*.txt;
*.csv)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
but because of comma delimiter i got to change it for
(*.txt)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
but dbq and extensions are invalid connection properties for FDO toolbox.
So i just leave the driver and i get this message
http://www.nabble.com/file/p21080382/error.jpg
Thanks
Jackie C. Ng wrote:
> You could try using FDO Toolbox (http://fdotoolbox.googlecode.com)
> connecting
> to the text file via the ODBC Provider (see examples here:
> http://www.connectionstrings.com/textfile) and bulk copy it to a new SDF.
> I
> haven't actually tried this approach myself, so your mileage may vary.
> - Jackie
> Moog wrote:
>> Hi,
>> I wonder if there's a way to create sdf3 files from a text file (SDF
>> loader
>> from mapguide 6.5 allows to create sdf files from text reading
>> coordinates
>> with a delimiter).
>> Or ¿can i use sdf loader from 6.5 and then use map to export this sdf2
>> into
>> a sdf3?
>> thanks
>> View this message in context:
>> http://www.nabble.com/SDF-convertion-question-tp21054445p21054445.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/SDF-convertion-question-tp1668183p1670662.html
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/SDF-convertion-question-tp21054445p21080382.html
