[mapguide-users] using Map3D styled feature layers in MapGuide
Warren Medernach wmedernach at rand.com
Sat Dec 20 09:58:54 EST 2008
Hi Jeff,
I don't believe the.layer file, as it is, can be loaded into MapGuide.
I suppose it could be tweaked/modified to match the xml structure of a layer def in MapGuide, and then pushed into MapGuide via the MapAgent tool.  But the easist method is probably just publishing the layer directly to MapGuide from AutoCAD Map.
Hope this helps.
Warren M
From: mapguide-users-bounces at lists.osgeo.org on behalf of JeffJensen
Sent: Fri 12/19/2008 6:47 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] using Map3D styled feature layers in MapGuide
Hello MapGuide Users,
How do I load a Map3D styled feature layer (XML file with .layer extension)
in MapGuide Server?
Map3D 2009 documentation discusses the .layer file (
http://images.autodesk.com/adsk/files/autocad_map_3d_user_s_guide.pdf#page=571).
This is a handy way to preserve your symbology/thematic maps and data
connections to GIS data such as shapefiles. The end user can just drag and
drop the .layer into the Display Manager of Map3D and assuming you haven't
broken the link to the shapefile by moving it, you should have thematic map.
I was told this .layer file can also be used with MapGuide but I don't see
how I can load into MapGuide Studio or where to upload the file into
MapGuide Server.
Thank you for your assistance,
Jeff Jensen
View this message in context: http://www.nabble.com/using-Map3D-styled-feature-layers-in-MapGuide-tp21099207p21099207.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
