[mapguide-users] Fusion and .NET Development
Berdel, Brian brian.berdel at mcmtrans.com
Tue Dec 23 10:34:59 EST 2008
Something like this will work
public string GetParameter(NameValueCollection parameters, string name)
    string strval = parameters(name);
    if (strval == null) {
        return "";
    return strval.Trim();
    string mgSessionId = null;
    NameValueCollection parameters = default(NameValueCollection);
    if (System.Web.HttpContext.Current.Request.HttpMethod == "POST") {
        parameters = System.Web.HttpContext.Current.Request.Form;
    else {
        parameters = System.Web.HttpContext.Current.Request.QueryString;
    string mapName = GetParameter(parameters, "MAPNAME");
    string session = GetParameter(parameters, "SESSION");
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of KeithC
Sent: Tuesday, December 23, 2008 9:20 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Fusion and .NET Development
Thanks Brian.
How do I get the session ID, etc from Fusion? I need to pass these to
the
backend.
Regards,
Keith
Berdel, Brian wrote:
> If you were successful with the regular Ajax viewer you can hook to
the
> task pane of fusion using the intitial url or use an invoke url script
> to access the .net pages via a new window or the task pane. The
mapguide
> webapi is still accessible in fusion.
> Brian
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, December 23, 2008 8:23 AM
> Subject: [mapguide-users] Fusion and .NET Development
> What is the easiest way to hook .NET based App development into
Fusion?
> I
> have an application that uses the web API in C# and I'd like to make
> this
> available in a flexible layout. I don't wish to rewrite the App in
PHP.
> I do
> need to extract some parameters from the client side to send to the
> server,
> such as session ID, map name and web agent url, but it's not clear how
> to do
> this.
> Keith
http://n2.nabble.com/Fusion-and-.NET-Development-tp1693730p1693730.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/Fusion-and-.NET-Development-tp1693730p1693910.html
