[mapguide-users] Selection in Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Wed Dec 24 15:41:33 EST 2008
I had that problem before...It had to do with either null values in data
fields or a column name...
Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Tuesday, December 23, 2008 7:21 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Selection in Fusion
I'm using MGOS 2.02 and IIS 7 on Vista x64.  I'm having problems setting
the selection in fusion.
I step through the code and get this error in  fusion.js at
ajaxException:
SetSelection Exception: An unclassified exception occurred.
Exception occurred in method MgSelectionBase_FromXml at line 12308 in
file .\MgApi_wrap.cpp
Everything seems to be in order, i just can't seem to figure out what is
causing it to break.
My selection xml is as follows:
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="75d6a8aa-0000-1000-8002-0021706d98cf">  <Class id="Default:Jobs">
<ID>AQAAAA==</ID>  </Class> </Layer></FeatureSet>
Is anyone else having this problem with setting the selection?
PLEASE HELP!!!!
Thanks.
-Mark Pendergraft
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081224/e3c99073/attachment.html
