[mapguide-users] GetMapImage
wordsy mwordell at gmail.com
Mon Dec 29 18:33:12 EST 2008
I am hoping someone here has had the same problem.
My scenario:
I have a grid of items that are on a map (layers etc).  This page does not
have the main map.  I have a requirement where a user can click on the item
in the grid (asp.net datagrid) and they will be able to see a preview of the
item they have clicked on.  I am using the GetMapImage in a user control.  I
have successfully created the control so it goes to the item picked in the
list and renders that image.  The only problem I have is actually selecting
the item in the map by.
Here is the code I am using:
 string searchstring = "SpatialKey = '" + this.RadTextBox1.Text + "'";
            MgFeatureQueryOptions DisplayIdQuery = new
MgFeatureQueryOptions();
            DisplayIdQuery.SetFilter(searchstring);
            MgUserInformation userInfo = new
MgUserInformation(Session[SessionStateBase.SESSION_GIS_SESSION_ID].ToString());
            MgSiteConnection siteConnection = new MgSiteConnection();
            siteConnection.Open(userInfo);
            // get the map
            MgMap map = new MgMap(siteConnection);
map.Open(Session[SessionStateBase.SESSION_MUNICIPALITY].ToString());
            MgAgfReaderWriter geometryReaderWriter = new
MgAgfReaderWriter();
            MgLayer layer = map.GetLayers().GetItem(LayerName) as MgLayer;
            MgFeatureReader featureReader =
layer.SelectFeatures(DisplayIdQuery);
            featureReader.ReadNext();
            MgByteReader byteReader = featureReader.GetGeometry("Geometry");
            MgGeometry geometry = geometryReaderWriter.Read(byteReader);
            MgPoint point = geometry.GetCentroid();
            double x = point.GetCoordinate().GetX();
            double y = point.GetCoordinate().GetY();
            MgSelection selection = new MgSelection(map);
           /////THIS IS WHERE I AM HAVING THE PROBLEM/////
            selection.AddFeatures(layer, featureReader, 0);
            //selection.Add(layer.GetObjectId(), map.GetClassName(),
this.RadTextBox1.Text);
            String selectionXml = selection.ToXml();
            selectionXml = Regex.Replace(Server.UrlEncode(selectionXml),
"%.{2}", new MatchEvaluator(CapitalizeEncoding));
            this.Image1.ImageUrl =
"http://vmedmgis/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE&VERSION=1.0.0&SESSION="
+ Session[SessionStateBase.SESSION_GIS_SESSION_ID] + "&MAPNAME=" +
Session[SessionStateBase.SESSION_MUNICIPALITY] +
"&LOCALE=en&MAPDEFINITION=Library%3A%2F%2F&FORMAT=PNG&SELECTION=" +
selectionXml + "&SETVIEWCENTERX=" + x.ToString() + "&SETVIEWCENTERY=" +
y.ToString() + "&SETVIEWSCALE=" + ViewScale.ToString() +
"&SETDISPLAYDPI=75&SETDISPLAYWIDTH=375&SETDISPLAYHEIGHT=250&SHOWLAYERS=&HIDELAYERS=&SHOWGROUPS=&HIDEGROUPS=&CLIP=0";
When I select the item on the map and get the selectionXml javascript
function I get
<FeatureSet>
<Layer id="6b85dffc-0000-1000-8000-005056c00008">
<Class id="Classname">
<ID>3QEAAA==</ID>
</Class>
</Layer>
</FeatureSet>
but when I run String selectionXml = selection.ToXml();
my code doesn't resemble the javascript xml.  Below is what I get.
<?xml version=\"1.0\" encoding=\"UTF-8\"?>
<FeatureSet xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
xsi:noNamespaceSchemaLocation=\"FeatureSet-1.0.0.xsd\">
</FeatureSet>
As you can see, there is a major difference between the 2 selection xml.
When I pass the selection xml generated by the server side code to the
GetMapImage function the formats aren't the same.
Any ideas why?  Thanks for any help in advance.
View this message in context: http://n2.nabble.com/GetMapImage-tp2090701p2090701.html
