[mapguide-users] Retrieving Ajax viewer
padmini godavarthi godavarthi.padmini at gmail.com
Tue Dec 30 04:50:10 EST 2008
Thanks for ur reply.but my problem is that iam unable to login to the nobble
forum.Its says invalid login.Thats y iam mailing u.
Now my problem is that
1)i want to do thematic mapping programmatically based on the some
condition.How is it possible.
2)Can u provide me some code(either in php or .net ) so that it will helpful
to me.
Thanks and Regards,
Padmini.
On Fri, Dec 26, 2008 at 8:06 AM, Kenneth Skovhede, GEOGRAF A/S (via Nabble)
<ml-user+64672-1943500107 at n2.nabble.com<ml-user%2B64672-1943500107 at n2.nabble.com>
> wrote:
> You don't have to remove the buttons.
> Right under the field where you select what map to use,
> there is a bunch of checkboxes. Remove the check mark in those.
> (Above the list of commands).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
> Hi,
> Thanks
> I tried it.But empty toolbar strip was displaying on the top of themapframe.at the left side also i dont want the legend control and properties
> diplayer. i want only that ajax viewer panel which displays the map.
> can u give me the suggestion?
> Thanks and Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>   Just create a weblayout with nothing visible (the map is obviously
> always visible).
> Then you can provide all the stuff you want from Visual Studio (buttons,
> menus, etc.).
> The setup is the same as described in the developer guide, but the
> toolbar, etc, won't be visible,
> and you will have to create it yourself.
>    Hi,
> Thanks for u r reply.
> But  iam using new visual studio web solution.i want this ajax viewer
> only
> in my web page
> How is it possible?
> Thanks and Regards,
> Padmini
> You can remove the toolbar and others, in the WebLayout, using Studio or
> Maestro.
>   Hi,
> Iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) by using
> ajax
> viewer .
> Now i want to get only ajax viewer  not all the toolbars,taskpanes all
> these
> things.
> i found that this map pane retrieved from the ajaxmappane.tmpl(from
> www/viewerfiles) but i didnt get the exact code for retrieving only
> that
> ajaxviewer.
> can u tell me the procedure(code for calling this mappane only) to get
> only
> that ajax viewer.
> Thanks and Regards,
> Padmini
> mapguide-users mailing listmapguide-users at ... <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=1819176&i=0>http://lists.osgeo.org/mailman/listinfo/mapguide-users
>       _______________________________________________
> mapguide-users mailing listmapguide-users at ... <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=1819176&i=1>http://lists.osgeo.org/mailman/listinfo/mapguide-users
> mapguide-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=1819176&i=2>
>  This email is a reply to your post @
> http://n2.nabble.com/Retrieving-Ajax-viewer-tp1819171p1819176.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Retrieving-Ajax-viewer-tp1819171p2091844.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081230/324dcd24/attachment.html
