[mapguide-users] layerdefinitionfactory with .NET
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 31 05:25:36 EST 2008
I don't know where or what the LayerDefinitionFactory is, but to add
thematic rules
you simply add a "PointRuleType", "LineRuleType" or "AreaRuleType" to the
"PointTypeStyleType", "LineTypeStyleType" or "AreaTypeStyleType"
collection of the
desired scalerange.
eg:
PointRuleType prt = new PointRuleType();
prt.Filter = "\"ID\" > 100";
//TODO: Set style and other properties
LayerDefinition ldef; //<-- Assign this
VectorLayerDefintionType vldef = ldef.Item as VectorLayerDefinitionType;
//If you have more than just points, you must itterate the "Items" to
find the right one
PointTypeStyleType pst = vldef.VectorScaleRange[0].Items[0] as
PointTypeStyleType;
pst.PointRule.Add(prt);
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> i want to do thematic mapping in .net .for that i suppose to use
> LayerDefinitionFctory .
> how to use it in .net?
> can u send me the code in .net
> Thanks and Regards,
> Padmini
> m.karam wrote:
>> Hi,
>> Many thanks for you Jackie
>> it works good
>> Regards
>> Karam
>> Jackie Ng wrote:
>>> Hi there,
>>> There is no .NET equivalent to LayerDefintionFactory. You'll have to port
>>> it over to .net.
>>> layerdefinitionfactory.php simply takes a bunch of xml templates in the
>>> "viewerfiles" directory of your web extensions install folder and fills
>>> in the blanks with the parameters you provide.
>>> example of CreateAreaRule() in .net:
>>> class LayerDefinitionFactory
>>>     public static string CreateAreaRule(string legendLabel, string
>>> filterText, string foreGroudColor)
>>>         StreamReader reader = new StreamReader("path/to/arearule.templ");
>>>         string areaRuleXml = reader.ReadToEnd();
>>>         string [] values = new string[] { legendLabel, filterText,
>>> foreGroundColor };
>>>         areaRuleXml = Substitute(areaRuleXml, values);
>>>         return areaRuleXml;
>>>     static String Substitute(String templ, String[] vals)
>>>         StringBuilder res = new StringBuilder();
>>>         int index = 0, val = 0;
>>>         bool found;
>>>         do
>>>             found = false;
>>>             int i = templ.IndexOf('%', index);
>>>             if(i != -1)
>>>                 found = true;
>>>                 res.Append(templ.Substring(index, i - index));
>>>                 if(i < templ.Length - 1)
>>>                     if(templ[i+1] == '%')
>>>                         res.Append('%');
>>>                     else if(templ[i+1] == 's')
>>>                         res.Append(vals[val ++]);
>>>                     else
>>>                         res.Append('@');    //add a character illegal in
>>> jscript so we know the template was incorrect
>>>                     index = i + 2;
>>>         } while(found);
>>>         res.Append(templ.Substring(index));
>>>         return res.ToString();
>>> Other CreateXXX functions are variations on the above example.
>>> Regards,
>>> - Jackie
>>> m.karam wrote:
>>>> Hi everybody
>>>> How can I use the (layerdefinitionfactory.php) API functions witn .NET ?
>>>> thanks
>>>> Karam
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081231/b4cfe986/attachment.html
