[mapguide-users] RC2 fusion samples question (simple sample)
Mike Adair madair at dmsolutions.ca
Fri Feb 8 09:05:05 EST 2008
Zac,
The MapGuide simple sample in Fusion hasn't yet been converted from an
older version of the code.  This has been fixed and will be available in
the next RC.
For the gmapTiled map definition, I'll have to confirm but we should be
able to make a package for that available.
Mike
Zac Spitzer wrote:
> I have successfully installed the rc2 side by side with my existing
> 1.20 installation.
> On looking at fusion, the simple sample refers to
> Library://Samples/Gmap/Maps/gmapTiled.MapDefinition
> which I don't have ( i have just installed the Sheboygan sample)
> Is this available? I tried to edit the WebLayout.xml in that directory
> to point to the Sheboygan map definition but
> that doesn't seem to work, and i can't see it being loaded using
> livehttpheaders
> I am also seeing fusion generating a 404
> [Fri Feb 08 17:42:45 2008] [error] [client 192.168.1.3
> <http://192.168.1.3>] File does not exist: C:/Program
> Files/MapGuideOpenSource2.0/WebServerExtensions/www/fusion/samples/mapguide/simple/ApplicationDefinition.xml,
> referer: http://zac:8018/mapguide/fusion/samples/mapguide/simple/
> z
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
