[mapguide-users] MGOS 2.0.0 RC 3 loadfile error
Ben_GeoIt ben.schalley at geoit.be
Wed Feb 13 04:15:03 EST 2008
Jim O'Leary wrote:
> I have installed MapGuide Open Source 2.0.0 Beta 2 on Windows Server 2003.
> We also have MGE 2008 running on this machine.
> The MGOS web server does not start. When I manually try to start it, it
> says:
> httpd.exe: Syntax error on line 126 of C:/Program
> Files/MapGuideOpenSource2.0/We
> bServerExtensions/Apache2/conf/httpd.conf: Cannot load
> ../Php/MgHttpHandler.dll
> into server: The specified procedure could not be found.
> It is this line that causes the failure:
> LoadFile ../Php/MgHttpHandler.dll
> However, the MgHttpHandler.dll is there. The other DLLs appear to load.
Yesterday I installed MapGuide Open Source 2.0.0 RC3 on my development
machine, Windows XP Professional sp2, following the instructions
http://trac.osgeo.org/mapguide/wiki/InstallSideBySide1.2and2.0IIS for a side
by side install with MGOS 1.2 on IIS.
I have the same issue as described above by Jim O'Leary.
Anyone with an idea as how to solve this issue?
Thanks
Ben Schalley
Analyst-Programmer
Geo-IT BVBA
 | Silicon Building – Wilrijkstraat 37 | 2140 Antwerp | Belgium
Tel: +32 (0)3/272 03 13 | Mobile: +32 (0)475/96 59 48 | Fax: +32 (0)3/272 03
14
Web: http://www.geoit.be
View this message in context: http://www.nabble.com/MGOS-2.0.0-Beta-2-loadfile-error-tp14373978s16610p15451861.html
