[mapguide-users] InvokeUrl in MGOS 2.0 BETA
J Manafi jonathan.manafi at cctechnol.com
Fri Feb 15 11:59:38 EST 2008
Update:
I have our script now at least outputting that nothing was selected.
For anyone that may run into a similar problem, I wasn't aware that some of
the initial setup has now been done already in MGOS 2.0. For instance,
   InitializeWebTier();
   $siteConnection = new MgSiteConnection();
and some others have already been setup in fusion/MapGuide/php/Common.php,
so we had to just comment out some portions that were conflicting with the
variables already setup, as well as rework a few lines to ensure
compatibility.
Hope this helps someone else.
J Manafi wrote:
> Hi all,
> I am new to MapGuide, and I had just learned enough of 1.2 to make
> enhancements/modifications to some of our existing code, and then I
> started testing 2.0.X for the eventual upgrade. We had a php script that
> was used as an 'invokeUrl' in 1.2 that was working fine, but I am not sure
> how the new javaScript InvokeUrl widget works exactly. Now, it tells me
> that some javaScript functions are undeclared when they are clearly
> declared and defined inline above the actual call. Has anyone tried and
> been successful with invokeUrl in 2.0? And if so, is it possible to know
> how invokeUrl behaves differently now?
> Any and all help is appreciated.
> Thanks,
> Jonathan
View this message in context: http://www.nabble.com/InvokeUrl-in-MGOS-2.0-BETA-tp15148563s16610p15502983.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080215/aa68b048/attachment.html
