[mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
Berdel, Brian brian.berdel at mcmtrans.com
Mon Feb 18 09:44:28 EST 2008
I was installing the asp.net server extensions but you need PHP either
way in order to run the server admin stuff and Vista / II7 does not
natively support it, you have to install it and configure yourself.
Even after doing that, I was still having issues, so I basically gave up
because it was taking too much time.
2.0 would cause the same issues.
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of mkaram84
Sent: Monday, February 18, 2008 9:31 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
Hi Brian
1- Did you install PHP or ASP Web Extensions of MapGuide?
if you installed ASP and the MapGuide run with you, please tell me
How...
2- What about MGOS 2.0, can I run it under the same conditions ?
thanks for your reply
(sorry for my english)
Regards
Karam
Berdel, Brian wrote:
> I attempted to get it running but it was pretty difficult.  I believe
it
> is possible, with a lot of work.   I think Vista SP1 will have better
> support for PHP so I would wait for that before hosting a site on a
> Vista machine.
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Sunday, February 17, 2008 11:38 AM
> Subject: [mapguide-users] Run MGOS 1.2 with IIS 7 (Vista)
> Hi everyone ...
> Can I run MGOS 1.2 or MGOS 2.0 - in Windows Vista Business with IIS 7
> If yes, how can i run it?
> Thanx and Regards
> Karam
http://www.nabble.com/Run-MGOS-1.2-with-IIS-7-%28Vista%29-tp15457611s166
> 10p15457611.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
10p15546331.html
