[mapguide-users] Local drive vs Network drive with MGOS (Vista/XP)
Andy Morsell amorsell at spatialgis.com
Tue Feb 19 18:25:02 EST 2008
In Windows Explorer on your virtual machine, can you login and successfully
connect to the network locations in question?  If so, then the problem is
that the MapGuide Windows Service itself does not have necessary rights to
that location and is most likely running under a local system account (by
default) that does not have the necessary network privileges to that
location.  Go into Windows Services, find your MapGuide Open Source service,
go to it's properties, then to the Log On tab and change the account that it
runs under as one that has the correct privileges to those network
locations.
If this is not your problem and you cannot connect to network locations
outside of your VMWare instance under any circumstances, then you may have a
problem with your VMWare network adapter.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pierre Cardinal
Sent: Tuesday, February 19, 2008 3:04 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Local drive vs Network drive with MGOS
(Vista/XP)
Thank you both for your help but I still have the problem. Could it be
VMware? My OS are running in VMware with MGOS and I am trying to connect
with drive that are outside VMware (network drive).
Pierre
Pierre Cardinal wrote:
> Environment: XP or Vista with MG studio and MGOS 2.0 RC3.0
> It is possible with MG Studio to connect with data stored on local
> drives but not with data stored on network drives. What should I do to
> use an alias with a network drive? The problem is the same with ODBC
> (unable to connect with data stored on network drives).
> Pierre
View this message in context:
http://www.nabble.com/Local-drive-vs-Network-drive-with-MGOS-%28Vista-XP%29-
tp15518597s16610p15578351.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
