[mapguide-users] MGOS 2 RC4 on CentOS Build problems
Andy Morsell amorsell at spatialgis.com
Sun Feb 24 19:18:37 EST 2008
I'm trying to get MGOS 2 RC4 installed on Linux CentOS 5 distro and having
some troubles.  I think I have managed to get past a few of them, but am now
stuck.  I have succesfully installed the Apache-PHP-web extensions after
having to install many libraries that it was dependent on.  I then got FDO
3.3 installed with GDAL and MySQL support after having some problems with
environment variables not "sticking".
Now, I am trying to get MGOS installed and am stuck at build_oem.sh.  At
first it would fail at the DWF build stage, but I was able to configure/make
in the 3 DWF folders with success so I removed those items from
build_oem.sh.
I am now having problems with the build stage of the Berkely DB.  This
happens with either the build_oem.sh shell script or with the dbxml
buildall.sh script so I'm confident that's where things are failing.  Here
are the error messages:
yacc -d -v -o ../src/parser/XQParser.cpp ../src/parser/XQParser.y
make[1]: yacc: Command not found
make[1]: *** [../src/parser/XQParser.cpp] Error 127
make[1]: Leaving directory
`/Software/MGOS/mapguide-2.0.0/Oem/dbxml-2.3.10/xqilla/build'
make: *** [all-recursive] Error 1
BDBXML 2.3.10: Error build failed (0).................
So I installed byacc, then got this:
byacc: e - line 555 of "../src/parser/XQParser.y", syntax error
%pure_parser
So I installed bison, then got this:
./.libs/libxqilla.so: undefined reference to `XQParser::yyparse(void*)'
collect2: ld returned 1 exit status
make[1]: *** [xqilla] Error 1
And this is where I am stuck.  Any help is appreciated.  Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080224/19606828/attachment.html
