[mapguide-users] Issue with MGOS2.0 Beta 2
Andy Morsell amorsell at spatialgis.com
Tue Jan 1 12:58:04 EST 2008
Brad,
I also had some issues installing and getting it to work alongside MGE 2008
with both running IIS.  I decided to not go the IIS / Apache side-by-side
route (although I'm sure that would have worked fine).  Instead, I decided
to invest the time to set up some VMWare virtual machines so that I can more
easily test the releases in isolated environments with a minimum of
opportunity for conflicts.  I am currently testing MGOS 2 Beta successfully
this way and so far it is working well.  I have by no means been able to
load test or put it through it's paces, so don't have much feedback on
stability yet.
http://www.vmware.com/products/server/
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
Sent: Tuesday, January 01, 2008 9:41 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Issue with MGOS2.0 Beta 2
Happy New Year.  Have you or anyone found any improvements with the new Beta
MGOS?  Is it faster?  Is it stable? We are having problems installing it
along side MGE 2008 and I am wondering if it is worth it at this point.
thanks
mauro1970 wrote:
> Layers that use custom symbols don't display correctly. Symbols now
> appear on the left bottom corner. They showed ok in 1.2.
View this message in context:
http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p14568414.ht
ml
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
