[mapguide-users] Issue with MGOS2.0 Beta 2
Ivan Milicevic Ivan.Milicevic at supranet.hr
Tue Jan 1 17:56:53 EST 2008
Why do you use Apache instead IIS? Is it faster?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
Sent: Tuesday, January 01, 2008 7:18 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Issue with MGOS2.0 Beta 2
Thanks Andy,  we are using Apache with MGE2008 but Jim O. had problems
installing some dll files with the new beta software.  I like the idea
of
using the VMW software for testing so we will not corrupt or lose
anything.
Please let me know if I can test your new demo site via email if
possible.
thanks
Andy Morsell wrote:
> Brad,
> I also had some issues installing and getting it to work alongside MGE
> 2008
> with both running IIS.  I decided to not go the IIS / Apache
side-by-side
> route (although I'm sure that would have worked fine).  Instead, I
decided
> to invest the time to set up some VMWare virtual machines so that I
can
> more
> easily test the releases in isolated environments with a minimum of
> opportunity for conflicts.  I am currently testing MGOS 2 Beta
> successfully
> this way and so far it is working well.  I have by no means been able
to
> load test or put it through it's paces, so don't have much feedback on
> stability yet.
> http://www.vmware.com/products/server/
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, January 01, 2008 9:41 AM
> Subject: Re: [mapguide-users] Issue with MGOS2.0 Beta 2
> Happy New Year.  Have you or anyone found any improvements with the
new
> Beta
> MGOS?  Is it faster?  Is it stable? We are having problems installing
it
> along side MGE 2008 and I am wondering if it is worth it at this
point.
> thanks
> mauro1970 wrote:
>> Layers that use custom symbols don't display correctly. Symbols now
>> appear on the left bottom corner. They showed ok in 1.2.
http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p1456841
4.ht
> ml
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/Issue-with-MGOS2.0-Beta-2-tp14563310s16610p1456873
1.html
