[mapguide-users] Label Placement Buffers
Traian Stanev traian.stanev at autodesk.com
Sun Jan 6 14:12:23 EST 2008
I can't think of a simple way to do that. One solution would be to create a polygon layer with zone polygons that represent the unions of all parcels with the same zone. Then you could label the union polygons.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brabo
Sent: Friday, January 04, 2008 2:20 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Label Placement Buffers
Is it Possible to create label placement buffers?   Or in other words, can I
manipulate the spacing between labels on a map?
Basically I don't want a zoning-code label for each and every little parcel,
but rather have one label for a group of parcels with the same zoning.  I'm
using Mapguide Studio 2008 v1.2.
Thank you.
View this message in context: http://www.nabble.com/Label-Placement-Buffers-tp14622472s16610p14622472.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
