[mapguide-users] Get selected layers from server side
Ivan Milicevic Ivan.Milicevic at supranet.hr
Sun Jan 6 17:18:49 EST 2008
Try this J
MgSelection selection = new MgSelection(map);
      selection.Open(resourceService, "1"); //opens selection
      MgReadOnlyLayerCollection layers = selection.GetLayers(); //gets
layers from selection
      MgLayerCollection zdenci = map.GetLayers();
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Sunday, January 06, 2008 10:51 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Get selected layers from server side
I know there is always a way to submit a form via POST, but it can be an
unwieldy proces. I am interested to know if the MapGuide server can
supply a
list of selected layers to a server-side program.
Kori Maleski-4 wrote:
> I think this isn't possible when using the Ajax viewer, but is
possible
> when
> using the DWF viewer.
> Someone may correct me on that...
> Use the Script frame of the Ajax viewer to fire a Form Submit Post to
pass
> your selection set instead.
> Cheers,
> Kori Maleski
> From: mapguide-users-bounces at lists.osgeo.org
O'Leary
> Sent: January-04-08 6:13 PM
> Subject: [mapguide-users] Get selected layers from server side
> Is it possible to get a list of the map's selected layers from the
server
> side?
> I know I can get this by making an MgSelection and passing the
selection
> XML
> from the client to the server program, like:
> $selection = new MgSelection($map,$_REQUEST['selectionXML']);
> However, I don't want to pass a big selection XML string to the server
> program, as I am passing by GET and the selection XML could be greater
> than
> the browser handles.
> If I make the selection object without including the selection XML,
like
> $selection = new MgSelection($map);
> $selectedLayers = $selection->GetLayers();
> $numberLayers = $selectedLayers->GetCount();
> PHP tells me that $selectedLayers is not an object.
> Thanks.
http://www.nabble.com/Get-selected-layers-from-server-side-tp14628979s16
610p
> 14628979.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
610p14654216.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080106/a6149afb/attachment.html
