[mapguide-users] Get selected layers from server side
Ivan Milicevic Ivan.Milicevic at supranet.hr
Mon Jan 7 02:37:21 EST 2008
You're wellcome :-)
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Sunday, January 06, 2008 11:48 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Get selected layers from server side
Yes, this works. The part that I was missing was:
selection.Open(resourceService, mapName);
When you do this, you give the selection object access to the session
through the resource service object. Then it knows the layers that the
user
selected. Much cleaner than the JavaScript route.
Thanks.
Ivan Milicevic-3 wrote:
> Try this J
> MgSelection selection = new MgSelection(map);
>       selection.Open(resourceService, "1"); //opens selection
>       MgReadOnlyLayerCollection layers = selection.GetLayers(); //gets
> layers from selection
>       MgLayerCollection zdenci = map.GetLayers();
> From: mapguide-users-bounces at lists.osgeo.org
O'Leary
> Sent: Sunday, January 06, 2008 10:51 PM
> I know there is always a way to submit a form via POST, but it can be
an
> unwieldy proces. I am interested to know if the MapGuide server can
> supply a
> list of selected layers to a server-side program.
> Kori Maleski-4 wrote:
>> I think this isn't possible when using the Ajax viewer, but is
> possible
>> when
>> using the DWF viewer.
>> Someone may correct me on that...
>> Use the Script frame of the Ajax viewer to fire a Form Submit Post to
> pass
>> your selection set instead.
>> Cheers,
>> Kori Maleski
> O'Leary
>> Sent: January-04-08 6:13 PM
>> Subject: [mapguide-users] Get selected layers from server side
>> Is it possible to get a list of the map's selected layers from the
> server
>> side?
>> I know I can get this by making an MgSelection and passing the
> selection
>> XML
>> from the client to the server program, like:
>> $selection = new MgSelection($map,$_REQUEST['selectionXML']);
>> However, I don't want to pass a big selection XML string to the
server
>> program, as I am passing by GET and the selection XML could be
greater
>> than
>> the browser handles.
>> If I make the selection object without including the selection XML,
> like
>> $selection = new MgSelection($map);
>> $selectedLayers = $selection->GetLayers();
>> $numberLayers = $selectedLayers->GetCount();
>> PHP tells me that $selectedLayers is not an object.
>> Thanks.
>> View this message in context:
http://www.nabble.com/Get-selected-layers-from-server-side-tp14628979s16
> 610p
>> 14628979.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 610p14654216.html
610p14655121.html
