[mapguide-users] Fusion - 'Resource not found Error'
Suja Sudhan suja.sudhan at atkinsglobal.com
Tue Jan 8 08:18:22 EST 2008
Hi All,
I recently installed Fusion and the samples work fine with the sheboygan
mapdefinition. If I change the ApplicationDefinition.xml to load other maps,
I get an error saying 'Failed to load requested map - Resource (points to my
mapdefinition eg. library://test/test.mapdefinition) not found'. The
mapdefinition is valid and can be previewed using Studio.
Can someone point to what I am missing or what might have gone wrong?
Thanks for your time.
Suja
View this message in context: http://www.nabble.com/Fusion---%27Resource-not-found-Error%27-tp14689343s16610p14689343.html
