[mapguide-users] Mapguide with no map...
Marc Pfister mpfister at enplan.com
Tue Jan 8 15:30:49 EST 2008
I am using the Sheboygan data, and I checked the extents and they are
correct. I'm confused as to why the Sheboygan dataset is throwing
"Unsupported coordinate system code" when I'm trying to output to 4326.
That shouldn't happen.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Tuesday, January 08, 2008 12:06 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide with no map...
You should try with some data that you know the bounds of (Sheboygan
perhaps?).
I have seen many cases, where the auto-calculated map extents are wrong.
Regards, Kenneth, GEOGRAF A/S
Marc Pfister skrev:
The MG error log doesn't show any errors. The Admin log only shows
successes.
I did manage to generate an error message of sorts. If I use MapAgent to
generate a WMS GetMap request, using the default values it gives for the
Sheboygan dataset ( EPSG 4326 and lat lon bounds in the -87, 43 range),
I get this error:
The coordinate system conversion failed.
Unsupported coordinate system code. The coordinate system conversion
failed.
Exception occurred in method
MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in file
CoordinateSystem/CoordinateSystem.cpp
Proj is the bin folder, and executing ./proj returns the useage:
message.
I'm not sure what's going on, and without any more clues I might just
reinstall and see what happens.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan
Milicevic
Sent: Monday, January 07, 2008 11:55 PM
Subject: RE: [mapguide-users] Mapguide with no map...
Anything in MG server log???
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Marc
Pfister
Sent: Tuesday, January 08, 2008 1:50 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide with no map...
I recently installed Mapguide OS on Ubuntu using the wiki pages and
everything seemed to install correctly.
Apache starts and responds fine. I get directory listings and simple
pages or parts of pages.
Mapguide starts fine. Watching the output from starting the startup
shell script, it says it starts up and is using the Proj 4 library.
Map Admin works fine. I can load data packages, etc
However, I can't seem to get any map output.
WebStudio works, though never draws any sample maps (though it only
wants to look at 127.0.0.1, which isn't the right place to look on my
system)
The sample maps, like Sheboygan, don't seem to draw anything. I get a
blank page in the brower when I use the phpviewersample.
MapAgent works for requests like GetCapabilities, but also doesn't draw
any maps with the related tools. I don't know the extents of the sample
data, so maybe that's why I can't get an output from it.
In any case, I never see any error messages show up at the terminal. Is
there a way to make it more verbose?
My next step will be to load a sample shapefile of which I know the
extents so I can give it more complete request for an area to render.
Are there any other troubleshooting steps I should take?
n
Marc Pfister
Geospatial Data Manager
ENPLAN
530/221-0440 x108
530/221-6963 Fax
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080108/778b3bec/attachment.html
