[mapguide-users] Issues selecting a feature with custom coding
Jason Birch Jason.Birch at nanaimo.ca
Thu Jan 10 11:01:19 EST 2008
More details on this here:
http://tinyurl.com/2rrq3e
I'm definitely a bit rusty on this stuff, but in your initial problem
are you sure you want to be using a string value for the parcel id?
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Issues selecting a feature with custom
coding
Here are the results of both the mgos base64 value and the php
base64_encode
value:
Actual FeatId: 33181
MGOS Value: nYEAAA==
base64_encode Value: MzMxODE=
I found code for writing a base64 function in javascript, and it gives
the same result as the php function.
