[mapguide-users] Reg: MapGuide
Ajay Vikram Singh Ajay.Singh at headstrong.com
Fri Jan 11 01:48:08 EST 2008
I am new user of the map guide trying to explore the map guide open
source.
I am trying to run the example of map guide but getting the following
exception
Cannot establish connection.
I am not able to login on the mapadmin/login.php.
On the other machine with same configuration its running fine.
Please help me out regarding the following issues also:
PHP Installation required? If yes then how the mapadmin/login.php
running fine.
How to load the mgp file from admin page?
Please suggest me.
Thanks Allot
***The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review,retransmission,dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer.***
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080111/94946619/attachment.html
