[mapguide-users] Reg: MapGuide
Ivan Milicevic Ivan.Milicevic at supranet.hr
Fri Jan 11 02:27:00 EST 2008
http://download.osgeo.org/mapguide/releases/1.2.0-rc2/samples/Sheboygan.
mgp
here is mgp file. Put it in server/packages direcotry. Have you started
mapguide service?
Try opening http://localhost/mapguide/mapadmin/login.php (Administrator,
admin)
And then go to manage packages. You will able to se sheboygan.mgp in
list below, load that package...
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ajay Vikram
Singh
Sent: Friday, January 11, 2008 8:13 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Reg: MapGuide
First of all Thanks for the valuable information.
Actually I am trying to run the .Net examples. When trying to download
mgp file it's coming in text format.
And trying to create the packages but not able to do that. Please
suggest me.
Thanks allot.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan
Milicevic
Sent: Friday, January 11, 2008 12:24 PM
Try restarting mapguide service.
PHP instalation is included.
Download sheboygan.mgp and phpviewersample from downloads page.
Read getting started with mapguide at
http://mapguide.osgeo.org/1.2/documentation.html
Wellcome!
Singh
Sent: Friday, January 11, 2008 7:48 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Reg: MapGuide
I am new user of the map guide trying to explore the map guide open
source.
I am trying to run the example of map guide but getting the following
exception
Cannot establish connection.
I am not able to login on the mapadmin/login.php.
On the other machine with same configuration its running fine.
Please help me out regarding the following issues also:
PHP Installation required? If yes then how the mapadmin/login.php
running fine.
How to load the mgp file from admin page?
Please suggest me.
Thanks Allot
***The information transmitted is intended only for the person or entity
to which it is addressed and may contain confidential and/or privileged
material. Any review,retransmission,dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you
received this in error, please contact the sender and delete the
material from any computer.***
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080111/4212d620/attachment.html
