[mapguide-users] King Oracle Problem
Zac Spitzer zac.spitzer at gmail.com
Tue Jan 15 04:06:03 EST 2008
if you do use the instant client version, make sure the oci*.dll's are in
the bin\FDO directory and not in a subdirectory
z
On Jan 15, 2008 7:45 PM, Simon Pelicon <simon at sl-king.com> wrote:
>  No, Instant Client is not necessary if you use Oracle 10g client.
> In this case you have to download King Provider for <http://www.sl-king.com/fdooracle/download/FdoKingOracle_Win32_FDO_3_2_2_v0_7_3.zip>v0.7.3
> Windows 32-bit provider for Oracle 10.2 Client<http://www.sl-king.com/fdooracle/download/FdoKingOracle_Win32_FDO_3_2_2_v0_7_3.zip>
> and not for Instant Client.
> Simon
> JeromeA wrote:
> Hm, jes could be. But I also tried to install Oracle 10g client, wich works,
> and deinstalled the 9i Client. So there is no Instant Client necessary,
> isn't it?
> Simon Pelicon wrote:
> Did you by mistake downland 64bit version of oracle instant client
> instead of 32bit?
> Simon
> JeromeA wrote:
>   Hi,
> I've got a MGE 2008 trial, with FDO 3.2.2. I downloaded Fing for 3.2.2. I
> restarted several times.
> I also tried the dependency walker wich shows a few missing files (see
> attached image).
> Thanks for your help ,
> Jerome
>     Hi,
> Which version of MapGuide do you have?
> There are providers v0.7.3 for different FDO versions (3.1 ,3.2 and
> .3.2.2)
> Do you restart MG server after changing provider files,xml etc...?
> You can also check which files are missing or wrong , using "Dependency
> walker" http://www.dependencywalker.com/
> With Dependency W. open KingProvider.dll.
> Simon
>   http://www.nabble.com/file/p14833719/dependency.jpg
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080115/dd5c35f6/attachment.html
